97 arctic cat bear cat 454 voltage regulator
Old Aug 7, 2017 | 10:48 AM
ghostriderus's Avatar
Default 97 arctic cat bear cat 454 voltage regulator
i have a 97 arctic cat bear cat 454 4 wheel drive 4 wheeler. the battery charging circuit is not charging the battery. after some checking i have found the connector from the voltage regulator was full of dirt and the center wire in the connector had got hot and melted. after jumping that wire bypassing the connector, still no difference. then when i did the ohm tests on the regulator, i have absolutely no connectivity between any of the wires coming from the regulator. even when i reversed the ohm meter leads. i am now going to assume the regulator is burned out and was wondering if there was any other regulators of any other machines that would work on mine. or am i stuck paying big bucks for a stock one ?
PW1
Apr 24, 2015 08:08 AM
M249SAW
Aug 22, 2002 05:08 PM
Thor
Jul 19, 2002 05:00 AM
