2003 polaris 700 twin oil in coolant
Just installed starter and bendix. Thanks OPT for the help.
Put it all back together and knew is was idling rough so I sea foamed it and then changed the plugs. I was greasing and checking fluids as I had changed all fluids a few months ago.
When I went to check my antifreeze bottle saw it needed toping off. Pulled cap and it was like mayonnaise in the cap and rim.
It is still running rough when you give it gas but then it picks up ok with RPM's.No smoke or steam from engine exhaust.
So what is causing the oil in coolant and the bogging down on initial throttle? Oil is clear.
I can flush the coolant system but is that a fix? Also going to try and clean the carb.
Thanks for the help!
