How to install inner seal on front hub, 198 trail boss 250 4x4
Old Sep 4, 2017 | 06:06 PM
pigseye's Avatar
Default How to install inner seal on front hub, 198 trail boss 250 4x4
Hello!
Was working on front brakes and discovered the front left hub was leaking. Took it all apart, cleaned it up, and am now trying to install the inner seal and have two questions.
1) which side of the seal goes into the hub? I assumed that the if you can see the spring that side faces into the hub.
2) How do you get it into the hub? The seal is slightly oversized and when I try to press it in one "side" pops in and the other "side" pops out. I presume you don't just hammer it in.
Suggestions greatly appreciated.
Thanks
