2001 Polaris Sportsman 500 HO speedometer replacement
Old Sep 7, 2017 | 02:57 PM
Birddogk's Avatar
Default 2001 Polaris Sportsman 500 HO speedometer replacement
OPT, so far you are batting 2 for 2 on my list of problems solved. Here's another:
I need to replace the speedo on this old machine, any recommendations for good dealers selling this?
Also, are there any other similar models that used the same speedo?
Thanks.
Old Sep 7, 2017 | 04:27 PM
This is a hard one as the speedo is expensive new(around 400 bucks) and hard to trust a used one but up to you on this one. Shared year models with these.
Usage : 3280363
Year Product Model Assembly
2002 ATV SPORTSMAN 400 HANDLEBAR AND HEADLIGHT POD - A02CH42AA (4968536853C01)
2002 ATV SPORTSMAN 500 ALL OPTIONS HANDLEBAR AND HEADLIGHT POD - A02CH50 ALL OPTIONS (4967436743B13)
2002 ATV INT'L BIG BOSS 6X6 HANDLEBAR and HEADLIGHT POD - A02CL50AA/DA (4967986798D01)
2002 ATV SPORTSMAN 6X6 HANDLEBAR and HEADLIGHT POD - A02CL50AA/DA (4967986798D01)
2001 ATV 500 MAGNUM 500 HDS HANDLEBAR and HEADLIGHT POD - A01CD50AA (4964196419B013)
2001 ATV MAGNUM 500 HANDLEBAR and HEADLIGHT POD - A01CD50AA (4964196419B013)
2001 ATV SPORTSMAN 400 HANDLEBAR and HEADLIGHT POD - A01CH42AA (4964436443B013)
2001 ATV SPORTSMAN 500 DUSE HO HANDLEBAR and HEADLIGHT POD - A01CH50AA (4964466446B013)
2001 ATV SPORTSMAN 500 HO HANDLEBAR and HEADLIGHT POD - A01CH50AA (4964466446B013)
2001 ATV SPORTSMAN 500 RSE HO HANDLEBAR and HEADLIGHT POD - A01CH50AA (4964466446B013)
2001 ATV WORKER 500 HANDLEBAR and HEADLIGHT POD - A01CH50AA (4964466446B013)
2001 ATV INT'L BIG BOSS 6X6 HANDLEBAR and HEADLIGHT POD - A01CL50AA (4964586458D001)
2001 ATV SPORTSMAN 6X6 HANDLEBAR and HEADLIGHT POD - A01CL50AA (4964586458D001)
There is one place that repairs them I've found.Look at the bottom of the page.Speedometer Repair
If you're inclined to do so there are a couple posts on repairing speedos.http://forums.atvconnection.com/pola...ml#post3232409
KA7OEI's blog: Repair of the speedometer on a Polaris Sportsman 500 4-wheeler Also on some models awd function doesn't work with a faulty speedo. You can jump the brown/white with the brown in the speedo connector to bypass the awd ground from going through the speedo if that happens.
Old Sep 7, 2017 | 05:11 PM
Birddogk's Avatar
Ok good deal. If I do the repair method, will the odometer miles be accurate?
If I choose to replace with new, will the miles be reset to zero?
Just trying to figure out if it is possible to know the actual machine miles. Thanks.
Old Sep 7, 2017 | 06:17 PM
Speedo miles will be accurate up until the time it broke.. What it actually has is any ones guess. There are videos I've seen on rolling back mileage on the drum,but I'd just leave it as is. A new speedo starts out at zero. Other options that people have used that had to have a speedo is Trail Tech Vapor.Trail Tech || Vapor - Speedometer & Tachometer
Old Sep 9, 2017 | 03:21 PM
Birddogk's Avatar
Thanks OPT, excellent info once again!
