2in Lift Kit for 2004 Sportsman 700
Old Sep 15, 2017 | 12:37 AM
Walter Fermoyle's Avatar
Default 2in Lift Kit for 2004 Sportsman 700
Got a 2in lift kit for my ride. Do I need longer shocks, a-arms, cv axles etc? Also installed an aftermarket Comet clutch claiming 25% better performance. Does this call for carb rejetting? And I want to install an afterket exhaust so may end up rejetting anyway. Its starting to get colder up here in Tununak Alaska now so winter riding is here. Any comments and help appreciated.
Old Sep 15, 2017 | 04:34 AM
Stress is mainly on the cv joints and boots because of extreme angles from lift kits. Stock jetting is 152.5 main,45 pilot jet.Colder the weather the leaner the jetting requirements in most cases. All depends on aftermarket items installed,plus plug chopping is the most important thing. Plug needs to be a tan to medium brown color. You can look at this list to give you an idea as to the kit they offer or individual jets that you think you may need.https://www.jetsrus.com/a_jet_kit_at..._2002-2006.htm
Old Sep 23, 2017 | 04:06 AM
switzomatic's Avatar
2" lift won't require any mods to your suspension, axles, or shocks. As for jetting, Polaris had them a bit on the rich side to start if I remember correctly. It will take some trial and error to get it right especially depending on weather, altitude, and mods...
