Brake Caliper cross reference
Hello I purchased a used 1994 Polaris 300 2x4 that "needed" front brakes. After tearing it apart I found the previous owner ran the brakes until the piston was rubbing on the rotor. I'm searching for new calipers and I was wondering if anyone knows what other models use the same caliper?
Thanks.
Thanks.
These models used the same L/h caliper. The updated part number is #1910173
Usage : 1910074
Year Product Model Assembly
1996 ATV SPORT 400L FRONT BRAKE - W968540 (4935863586B007)
1996 ATV TRAIL BLAZER ES FRONT BRAKE - W968540 (4935863586B007)
1996 ATV SCRAMBLER FRONT BRAKE Scrambler W967840 (4935823582B007)
1995 ATV MAGNUM 2X4 FRONT BRAKE ASSEMBLY Magnum 2x4 W957544 (4926852685B004)
1995 ATV SCRAMBLER 4X4 FRONT BRAKE ASSEMBLY Scrambler W957840 (4927252725B007)
1994 ATV 300 2X4 FRONT BRAKE ASSEMBLY 2x4 300 W947530 (4926742674B003)
1994 ATV 400L 2X4 FRONT BRAKE ASSEMBLY 2x4 400L W947540 (4926752675B003)
1994 ATV 300 4X4 FRONT BRAKE ASSEMBLY 4x4 300 W948130 (4926762676B006)
1994 ATV 300 6X6 FRONT BRAKE ASSEMBLY 6x6 300 W948730 (4926792679B006)
1994 ATV SPORT 400L FRONT BRAKE ASSEMBLY Sport 400L W948540 (4927232723B003)
1994 ATV TRAIL BLAZER FRONT BRAKE ASSEMBLY Trail Blazer W947221 (4926832683B002)
1994 ATV TRAIL BOSS FRONT BRAKE ASSEMBLY Trail Boss W948527 (4926822682B002)
1993 ATV 250 2X4 FRONT BRAKE ASSEMBLY - W937527 (4924022402b003)
1993 ATV 350L 2X4 FRONT BRAKE ASSEMBLY 2X4 350L W937539 (4924032403013A)
1993 ATV 250 4X4 FRONT BRAKE ASSEMBLY 4X4 250 W938127 (4924042404015A)
1993 ATV 250 6X6 FRONT BRAKE ASSEMBLY 6X6 250 W938727 (4924092409017A)
1993 ATV TRAIL BLAZER FRONT BRAKE ASSEMBLY Trail Blazer W937221 (4924082408012A)
1993 ATV TRAIL BOSS FRONT BRAKE ASSEMBLY Trail Boss W938527 (4924072407012A)
1992 ATV TRAIL BOSS 2X4 FRONT BRAKE ASSEMBLY 250 2X4 / W927527 (4922862286016A)
1992 ATV TRAIL BOSS 4X4 FRONT BRAKE ASSEMBLY 250 4x4 / W928127 (4922872287C006)
1992 ATV BIG BOSS 4X6 FRONT BRAKE ASSEMBLY 250 4x6 / W928627 (4922902290020A)
1992 ATV TRAIL BLAZER FRONT BRAKE ASSEMBLY Trail Blazer / W927221 (4922852285016A)
1992 ATV TRAIL BOSS 250 FRONT BRAKE ASSEMBLY Trail Boss / W928527 (4922892289016A)
1992 ATV TRAIL BOSS 4X4 STRUT ASSEMBLY 250 4x4 / W928127 (4922872287B009)
1991 ATV TRAIL BOSS 2X4 FRONT BRAKE ASSEMBLY 250 2X4 - Update (4919781978016A)
1991 ATV TRAIL BOSS 250 FRONT BRAKE ASSEMBLY Trail Boss - Update (4919771977016A)
These models used the same R/F caliper. Updated part number is 1910174
Usage : 1910075
1995 ATV 300 4X4 FRONT STRUT ASSEMBLY 4x4 300 W958130 (4930183018B005)
1995 ATV XPLORER FRONT STRUT ASSEMBLY XPLORER 4X4 W959140 (4930223022B006)
1994 ATV 400L 4X4 FRONT STRUT ASSEMBLY 4X4 400L W948140 (4926772677B004)
1994 ATV 300 4X4 FRONT STRUT ASSEMBLY 4x4 300 W948130 (4926762676B004)
1994 ATV NORWEGIAN 400L 6X6 FRONT STRUT ASSEMBLY 6x6 400L, SWEDISH S948740 and NORWEGIAN N948740 (4926812681016A)
1994 ATV SWEDISH 400L 6X6 FRONT STRUT ASSEMBLY 6x6 400L, SWEDISH S948740 and NORWEGIAN N948740 (4926812681016A)
1994 ATV NORWEGIAN 400L 4X4 FRONT STRUT ASSEMBLY SWEDISH 4x4 400L S948140 (4926912691B005)
1994 ATV SWEDISH 400L 4X4 FRONT STRUT ASSEMBLY SWEDISH 4x4 400L S948140 (4926912691B005)
1993 ATV 250 4X4 FRONT STRUT ASSEMBLY 4X4 250 W938127 (4924042404013A)
1993 ATV Euro 350L 4x4 FRONT STRUT ASSEMBLY 4X4 350L S938139 (4924342434014A)
1993 ATV 350L 4X4 FRONT STRUT ASSEMBLY 4X4 350L W938139 (4924052405014A)
1993 ATV Euro 350L 4x4 FRONT STRUT ASSEMBLY 4X4 350L W938139 (4924052405014A)
1993 ATV 250 6X6 FRONT STRUT ASSEMBLY 6X6 250 W938727 (4924092409015A)
1993 ATV Euro 350L 6x6 FRONT STRUT ASSEMBLY 6X6 350L S938739 (4924362436015A)
1993 ATV 350L 6X6 FRONT STRUT ASSEMBLY 6X6 350L W938739 (4924062406015A)
1993 ATV Euro 350L 6x6 FRONT STRUT ASSEMBLY 6X6 350L W938739 (4924062406015A)
There is a new set on ebay for 150 bucks for the pair.You might want to check around or do a google search on these part numbers to see if you can find them cheaper if you wish.I wouldn't trust used calipers unless they were guaranteed to work.The piston and seal repair kit alone is close to 50 bucks per caliper. NEW OEM Polaris Magnum Scrambler Xplorer Front Brake Calipers Pair LH RH | eBay
Usage : 1910074
Usage : 1910075
