HELP PLEASE new engine i have fuel and spark still wont start
Old Oct 2, 2017 | 05:50 PM
atv dread's Avatar
Default HELP PLEASE new engine i have fuel and spark still wont start
hey I bought a new engine for my quad and have hooked everything up I have spark and gas as I pulled the plug and gas was on it but it won't start just keeps cranking. now it is a new motor so I have not tested compression but you can feel it pushing the air when trying to start
Old Oct 3, 2017 | 02:58 AM
It is possible the engine has been assembled wrongly, timing out, valves not set right etc, but most likely, it hasn't got the right fuel/air mixture. Fit a new plug, even if your old one was "new" a dry plug may do the trick. If it has a manual choke, try without any choke. If auto, and doesn't start with the new plug, try with a hand over the air intake, in case the choke isn't working.
Old Oct 3, 2017 | 08:39 AM
atv dread's Avatar
so it is a manual choke and have tried it with the choke open and closed and still nothing it started once but died the minute i took my thumb off the throttle.
Going to try it again later tonight will post progress i did have to replace the 12v regulator because with it i had no spark then i removed it and and spark returned would that have anything to do with it.
Old Oct 3, 2017 | 09:32 AM
Zrock's Avatar
Super Quad Patrol
I had the same issue with a new engine. got it fired up once using quick start but had to feather the throttle. Then i could never get it to start again. It backfired so hard it blew teh back of the muffler off and 50 feet into the yard.. I figured timing was way out.. Ended up selling it as i did not want to dig any deeper.
Old Oct 3, 2017 | 11:55 AM
DirtDevil101's Avatar
Does it fire on starting fluid? If not then it's most likely compression or timing if you confirmed spark (and please shoot the SF down the plug hole & not into the intake track)...
atv dread
Oct 2, 2017 05:49 PM
