My nephew has the 300 2 stroke and it seems to be running in reverse
It is a 99 polaris 300 2 stroke and the carburetor is sending fuel back towards air filter, and sputters and will idle just will not run under a load.
Check compression first. If it's low(below 100psi) common problem for fuel to spray back towards the air filter if it can't compress the fuel/air/oil mixture into a fine mist for ignition. Also can be carb needle and seat could be worn allowing too much fuel in the cylinder. If compresion is over 100psi,you can see if a carb kit solves the problem.Shindy Carburetor Carb Rebuild Kit Polaris Xpress/Xplorer 300 1996-99 ATV 03-40 | eBay
