2004 330 valve cover oil leak
Old Oct 11, 2017 | 10:14 PM
850 trailrider's Avatar
Default 2004 330 valve cover oil leak
Hey guys Picked up an 04 atp with just over 1000 mi in good shape runs well but got smell of burning oil on exhaust pipe got service manual coming for it . Is it a fairly straight forward job for someone who is fairly mech. inclined? any tips or tricks from those who might have done?Thanks in advance
Old Oct 12, 2017 | 04:54 AM
Not that hard but the tank may have to be removed to get to the breather cover easily. Breather cover has a metal gasket that's prone to have oil seepage around it. A thin coat of silicone around the edges of the gasket can help the bolt the cover back on. Don't over look the crank case vent and hose at the back of the cover that goes to the air box for a any oil leaking.Valve cover o-rings may be worn and need to be replaced if leaking around this area also.
Attached Thumbnails 2004 330 valve cover oil leak-932d27821de6cc06f4ad723b264bcf544ab02a84.png
Old Oct 12, 2017 | 08:13 AM
Thanks OPT removed plastics down to tank was planning on taking off tank just left on in case I move from garage to shed before it turned into bigger project believe its coming between head and valve cover any fear of cam lifting out of journals with chain under tension or is this in rep. man.[ don't have yet ordered used copy] waiting to show up just thinking ahead Thanks again OPT
Old Oct 12, 2017 | 08:46 AM
Hopefully just the breather cover and not any thing major.That's the part that seeped the most.Easy to take off,no cam chain or cam removal. Just clean and use a little sealant around the gasket.
Old Oct 12, 2017 | 10:07 AM
looks like one more mating surface down where larger ?rockerbox that has parts1-2-3-4 meets #14 major deal? thanks
Old Oct 12, 2017 | 10:39 AM
I never had to remove this,the only leakers I had were from the cover,but if you want to seal it,a few bolts and off it comes.
Old Oct 14, 2017 | 02:54 PM
cleaned and resealed top of cylinder head up to breather cover no issues with cam exposed was just real careful not to disturb it used copper rtv leaving to dry 24 before starting it was relatively easy job hopfully no more burning oil smell next is fixing front front gearcase plastic cage going with aluminium one Thanks OPT
