2004 ATP front gearcase
Old Oct 15, 2017 | 01:58 PM
850 trailrider's Avatar
Default 2004 ATP front gearcase
Hey experts
need a little help tore into non working front end no fluid mainly pasty sludge !!! does anybody know where I can get a complete front end rebuilding kit with bearings and seals and an aluminium roll cage and rollers ?? cleaned it up put 12 volts to coil armature plate stuck well so hopefully dodged that expense are the ranger 500 front ends the same ? some part # are the same but cant find a complete kit My plastic roll cage is ok but rollers and springs are rusty Thanks in advance UPDATE FOUND THIS QUAD LOGIC # 100-2082 SAYS NOT COMPATABLE BUT ALL PART #SEEM TO BE RIGHT HEEEELLLLLPPPP
Old Oct 15, 2017 | 03:39 PM
These models used the same front diff as your model.
Usage : 1341497
Year Product Model Assembly
SERIES 11 PPS UTV 2X4/4X4/6X6 FRONT HOUSING - C11RD50AA/AB/C11RF50AA (4981898189D04)
2005 ATV MAGNUM 330 4X4 FRONT HOUSING - A05CD32AA/AB/AC (4994909490C06)
2005 ATV ATP 330 4X4 FRONT HOUSING - A05JD32AA (4995169516C12)
2005 ATV ATP 330 4X4 QUAD FRONT HOUSING - A05JD32EA (4995169516C12)
2005 ATV ATP 500 4X4 FRONT HOUSING - A05JD50AA/AB/AC (4995169516C12)
2005 ATV SPORTSMAN 400 FRONT HOUSING - A05MH42AB/AG/AH (4994229422D04)
2005 ATV SPORTSMAN 500 HO/INTL FRONT HOUSING - A05MH50AB/AC/AG/AH/AL/AT/FB (4994229422D04)
2005 ATV SPORTSMAN 600 FRONT HOUSING - A05MH59AK/AN (4994229422D04)
2005 ATV SPORTSMAN 700 EFI FRONT HOUSING - A05MH68AC/AS/AT/AU/AW (4994229422D04)
2005 ATV SPORTSMAN 700 FRONT HOUSING - A05MH68AK/AN/AD (4994229422D04)
2005 ATV SPORTSMAN 800 EFI FRONT HOUSING - A05MH76AC/AT/AU/AW (4994229422D04)
2005 ATV SPORTSMAN MV7 HOUSING, FRONT - A05MH68AP (4999609960D05)
2005 MIL SPORTSMAN MV 7 GEARCASE, FRONT - A05MH68MB (4999609960D05)
2005 RGR RANGER 2X4,4X4,6X6 FRONT HOUSING (4X4)(6X6) - R05RD50AA/AB/AC/AD/RF50AA/AB (4995359535E02)
2005 RGR RANGER XP HOUSING, FRONT - R05RD68AA/AB (4998269826D03)
2004 ATV MAGNUM 330 4X4 FRONT HOUSING - A04CD32AA/AB/AC (4994909490C06)
2004 ATV A04CH42AQ SPORTSMAN 400 FRONT HOUSING - A04CH42AQ/AR/AS/AT/AV (4987258725D01)
2004 ATV A04CH50AQ SPORTSMAN 500 FRONT HOUSING - A04CH50AO/AQ/AR/AS/AT/AV/AW/AX (4987258725D01)
2004 ATV A04CH59AK SPORTSMAN 600 FRONT HOUSING - A04CH59AK/AL/AN/AQ/AW (4987258725D01)
2004 ATV A04CH68AK SPORTSMAN 700 FRONT HOUSING - A04CH68AK/AL/AN/AO (4987258725D01)
2004 ATV A04CH68AU/CU SPORTSMAN 700 FRONT HOUSING - A04CH68AP/AQ/AU/CU (4987258725D01)
2004 ATV ATP 330 4X4 FRONT HOUSING - A04JD32AA (4987258725D01)
2004 ATV A04JD50AA ATP 500 4X4 FRONT HOUSING - A04JD50AA/AB/CA (4987258725D01)
2004 RGR RANGER 2X4,4X4,6X6 FRONT HOUSING (4X4) (6X6) - A04RD50AA/AB/AC/A04RF50AA (4987918791D02)
You can do the cross checking from this list as to where you want to take a chance on the Quad Logic kit working or not.Polaris Sportsman Ranger Front Differential Rebuild Kit - ALUMINUM CAGE | eBay
Old Oct 15, 2017 | 05:44 PM
OPT
That's the issue im having everthing that it fits is on the list exept the ATP maybe cause it is a CROSSBREED?????
Lists that it fits all 04 models you have listed OPT just a little hesitant to pull trigger think I am overthinking to much
Also how hard to get large bearing off ring gear only enough room to get small screwdriver do I need to get a bearing separator and puller from harbor freight looks like it would be big help for front input pinion also
Old Oct 16, 2017 | 09:21 AM
Possible they didn't list the Atp because not too many units were sold. My two cents is that Polaris wouldn't go to the trouble of making a different front diff for an Atp when the main difference between it and a Sportsman 500 was just the dump bed on the same year model. Bearing separators are a good tool to keep in the tool box. They always come in handy in pulling or at least moving tight fitting bearings out to where they then can be easily removed.
Old Oct 16, 2017 | 09:36 AM
Thanks OPT pinion bearing and large carrier bearing on hard going to borrow tools to get off easier did some homework part# for part# all the same, took a chance and ordered last nite got a message from them today and they said it will fit just not enough info on that model interested in getting all back together bought knowing front end was inoperable will let know how things go
Old Nov 25, 2017 | 04:30 PM
I figured I would close this one out and say QUAD-LOGIC Kit 100-2082 worked out fine! 4x4 on the ATP works well all parts worked out Even that big ginormous bearing was right came with 2 different sizes of seals and pinion bushings just had to match to my old ones VERY NICE ALL INCLUSIVE KIT hopefully helps someone else out TOO.
Old Nov 25, 2017 | 04:57 PM
Glad it worked out for you. This kit even shows to fit the 600,700 and 800 models also.
Amazon Amazon
Most of the individual aluminum cages listed on Amazon or ebay would fit all centralized diff models also.Guess it's just that they seemed to forget the Atp and just lumped it in with the Sportsman 500.
