Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
big problem
Old Oct 15, 2017 | 04:27 PM
duanedehart's Avatar
Default big problem
i have a 1998 4x4 Suzuki quad and gas is leaking into the carburetor how can I fix it
Thanks
Ron
Old Oct 16, 2017 | 03:01 AM
Hardly a Kids Quad then, but your float needle is stuck open, usually grit under the needle, but faulty needle or sunk float are other possibilities. On Suzukis this shouldn't matter too much as Suzuki fuel taps are worked by vacuum and should turn the fuel off when the engine stops unless you have the tap on prime, which you shouldn't, except for starting after running out of fuel. Some 90s Suzukis have a low level tank and a fuel pump, but same applies, when engine isn't running, fuel is not fed to carb.
Old Oct 16, 2017 | 07:38 AM
LT80's Avatar
LT80 Expert
Yup, clean the carb paying attention to the float needle. If the problem persists you may need a carb kit with the new needle and seat.
Running non ethanol fuel will help too.
10 Ringer
Dec 25, 2016 01:47 PM
89softail
Sep 2, 2016 11:09 AM
Garrett Moore
Aug 27, 2016 07:27 AM
