kawasaaki atv wont start but crank
Old Oct 19, 2017 | 10:43 AM
zkowalka's Avatar
Default kawasaaki atv wont start but crank
i cant get four wheeler start but it only crank
Old Oct 19, 2017 | 10:47 AM
DirtDevil101's Avatar
You need to confirm it has the following:
1) Spark - pull out the plug, ground to frame or wrench and verify you have spark
2) Fuel - if you have spark but not sure if plug is getting fuel (dry), then spray 2-3 seconds of starter fluid directly into plug hole, replace plug & crank. If it starts then dies it's not getting fuel
3) Compression - if you know it has spark and doesn't start on starter fluid you need to verify your compression...if too low it will not start...
Start with these first...
