turf mode switch
Old Oct 22, 2017 | 06:40 PM
850 trailrider's Avatar
Default turf mode switch
Any way to check awd 2x4 turf switch to check if making contact in turf mode awd works diagnostics show on &off awd goes into 2wd mode cant figure how to check turf says off in diagnostics contacts on throttle side left side on off on switch /headlight switch seems a little sticky also planned on replacing that one anyway
Thanks
Old Oct 22, 2017 | 07:18 PM
Easiest way to see if turf mode is engaging properly is jack the rear end up and hit the switch. In turf mode one wheel will lock,the other free wheel. If you have problems,the most common thing to fail was the diff lock solenoid. Item#13.
Attached Thumbnails turf mode switch-97576e28d1bff6840f36cf197a4d17bce1c88723.png
