98 sportsman 500 awd
Old Nov 11, 2017 | 04:19 PM
Whitetailhunter8955's Avatar
Default 98 sportsman 500 awd
I just changed from axles and now the front let left wheel does not turn. I jacked the whole wheeler up and the tire will rotate but when I out my hand on it I can stop it. I took the rotor off and the armature plate sticks to the coil but I and peel it off. Doesn't seem to be a very strong magnet.
I looked in my book to see what the ohms should be on the coil and I can not find it...
Old Nov 11, 2017 | 04:38 PM
Busy beaver today.. Wiring diagram usually show the coils ohms resistance.24-27 ohms on average between the gray and brown wires. If you haven't replaced the armature plates I'd do that as cheap as they are.If the hub coil checks out, another problem on some was that they'd lose ground from the switch,then to the terminal board, then to the hub coils. Some have made a common ground on the brown hub wires to a better ground area. You might try that also like in the video.
Old Nov 11, 2017 | 08:43 PM
I have a feeling there is a broken wore or pinched wire. My aunt's bf hit a tree and broke the cv shaft and powers controlling arm... Got that all changed and now that tire doesn't work right... I am getting some power down there but not sure how much... I will check that out tomorrow. Do i check the ohms where the wires plug in to the panel under the headlight?
Old Nov 12, 2017 | 08:48 AM
First make sure you're getting 12 volts to the gray wire at it's connector under the front panel. Have to be in gear,awd button on. On checking resistance,just pull the two wires from the connector and check.
Old Nov 25, 2017 | 06:22 PM
I changed the armature plates and the front tires turn under power now! Thanks opt!
Old Nov 26, 2017 | 09:03 AM
Simplest of parts that can cause problems. If an armature plate is magnetized,it can cause a hub to engage even if it's not in awd mode. If a plate is warped or worn,it may not be able to ride evenly on the strut sleeve and inner pole of the strut.Then the coil isn't able to pull the plate strong enough so it can "drag" and allow the hilliard to lock in the hub. Glad new ones solved the problem.
