jaguar500
Old Dec 3, 2017 | 12:39 PM
tcadle's Avatar
Default jaguar500
where can i find rear cv joint rebuild kits, boots and bearings
Old Dec 4, 2017 | 03:06 AM
Just googled it and this firm seems to have everything https://www.capadif.com/en/transmiss...uar-500cc.html
Old Sep 14, 2019 | 09:29 AM
JaggedOne07's Avatar
Default Jag 500 engine
Anyone know a good replacement engine for the 2007 Jag 500? Old age got the best of mine after 12 years and barely 200 miles on it.
Old Sep 15, 2019 | 01:47 AM
Well I put the link in my first reply, all you had to do was click it and then link to the engine. Here I've done it for you, https://www.capadif.com/en/engine-pa...uar-500cc.html Any Kazuma dealer should be able to supply an engine, but your bike won't be worth fitting one to. A good 12 year old Honda 500 Quad wouldn't cost over 3000 euro, never mind a Kazuma.
Old Sep 15, 2019 | 01:23 PM
Yeah, I know. Pretty much figured it's not even worthy of being a boat anchor now. Probably look into a couple years old new Honda. Just thought I'd ask though. Seen the engine you posted. Kazuma USA has the engine listed for $2,999.00. Can buy a whole new machine for not much more than that. Maybe someone could use mine for parts. Has the upgraded tank with 2 outlets, 2 piece front cover (still have the one piece also) and have the upgraded heavier tie rod ends which I haven't installed. Still runs but makes some noise. I may keep the aluminum wheels if I should get something with the same bolt pattern.
Old Sep 16, 2019 | 02:02 AM
May be worth getting a motorcycle or quad mechanic to take a look at the engine. Not all noises are costly to fix, and it looks like Kazuma spares are available, unlike many Chinese/Taiwanese offerings.
Old Sep 16, 2019 | 03:26 AM
I did take it to a Chinese dealer and they said head gasket was gone, bearings gone, radiator has leaks (which I never noticed leaking). They seemed to think it had just water in it and I never put straight water in it. Also said there are no rebuild kits for it either. You'd think being an old Polaris clone engine parts would be interchangeable but I'm sure it would still cost too much and not be worth it.
Polaris bob66
Technical and How-To Articles
Jan 27, 2014 10:33 AM
Cookie66
Mar 25, 2010 07:23 AM
roofdogbill
Dec 31, 2008 08:12 PM
dodgeman1997
May 12, 2008 09:07 PM
NascarFan
Jun 8, 2004 11:34 PM
