2005 Baja 300cc extreme - parts
I need some parts for this quad - or if anyone can help me find the specs to find the chinese equivelant to this quad it would be greatly appreciated
carburetor
fuel tank
fuel shut off
carburetor
fuel tank
fuel shut off
Baja Parts Catalog | Baja Kart Parts | Baja ATV Parts Seem to be the spares supplier, but all your requirements are "no longer available." A link on this forum has the engine down as a Suzuki GN250 clone, so the carb for this may fit. If the tap is vacuum operated, you can bet it is Suzuki clone too.
If your problem is dirt, I would advise cleaning what you have, and fit an in-line filter.
baja parts catalog baja kart parts baja atv parts seem to be the spares supplier, but all your requirements are "no longer available." a link on this forum has the engine down as a suzuki gn250 clone, so the carb for this may fit. If the tap is vacuum operated, you can bet it is suzuki clone too.
If your problem is dirt, i would advise cleaning what you have, and fit an in-line filter.
Stephan Olivier
1) Engine problems..
Mar 6, 2013 01:13 AM
