I Yes my speedometer quit working my top main headlight 4x4 quit working in my
Old Jan 12, 2018 | 04:05 PM
Chad Spears's Avatar
Default I Yes my speedometer quit working my top main headlight 4x4 quit working in my
[QUOTE][/QUO Yes my speedometer quit work in my head like quit working and my 4 wheel drive quit working at the same time in as wondering if it was a fuse blow
Old Jan 12, 2018 | 04:27 PM
What model? If it's not showing speed or mileage,it may just be a hall effect sensor on the front strut that's out.If the speedo is dead,the yes many had the awd ground circuit go through the speedo and you would loose awd. You can bypass the speedo by jumping the brown/white wire(awd ground) to a common brown(ground) in the speedo harness or frame ground and you should be able to at least have awd. Some have repaired their speedos. Info is there if you care to at least try.http://forums.atvconnection.com/pola...ml#post3232409 KA7OEI's blog: Repair of the speedometer on a Polaris Sportsman 500 4-wheeler
weedy
Apr 24, 2010 09:15 AM
HARLEY_OWNER
Jul 1, 2008 04:42 PM
POLTAB
Dec 16, 2006 07:06 PM
LikeitsStolen
Where to Ride
19
Sep 5, 2005 03:39 PM
Highjumper1
Apr 12, 2000 10:58 PM
