Polaris Predator 500 turns off
Old Feb 6, 2018 | 08:08 PM
ErickAV33's Avatar
Default Polaris Predator 500 turns off
I have a 2003 polaris Predator 500 , and when i have 20-25 minutes running te ligths ,fan and all the quad turns off ,after 1 minute the ligths and fan try to work again and then i can turn on the quad but after 3 or 4 minutes it does the same , what could be the problem?
Old Feb 6, 2018 | 09:46 PM
RedRocket204's Avatar
Have your battery load tested or just buy a new one if it has never been replaced. You may want to test your stator also as it sounds like the battery is not charging when running. I've not owned a Polaris but your issue definitely sounds related to the battery/charge.
Old Feb 7, 2018 | 01:34 AM
First off check battery connections plus check that it's charging around 14 volts back to the battery.Sounds like the 20 amp thermal circuit breaker is crapping out on you. They can kick on and off if over heated,corroded or just worn out.Then kick back on when cooled down a bit. Should be in a plastic pouch on the main harness located up from the battery.Check for power on each side of the red wire on the pouch when it dies. If power isn't going through,slice the pouch open and replace the breaker. The parts break down doesn't show its location but lists it along with the 10 amp fan circuit breaker. Item #2. https://www.partzilla.com/catalog/po...-ab/electrical You can get these at any auto store for about 8-10 bucks.
Attached Thumbnails Polaris Predator 500  turns off-s-l1000.jpg   Polaris Predator 500  turns off-1000936wj9.jpg
Old Feb 7, 2018 | 04:06 PM
ErickAV33's Avatar
Thanks for all your help
Stayke
Jul 31, 2012 07:18 AM
prevacg
May 10, 2012 03:37 PM
polarisbear500
Dec 30, 2007 11:07 PM
crazyhead
Oct 9, 2005 10:03 AM
E
Apr 12, 2004 12:49 PM
