2004 Bombadier Outlander 330
Have coolant leaking from where Radiator outlet hose connects to engine. Cannot tell if it is hose or beneath hose where it is connected.I can find hose part # and diagram but what is the engine part to which it is connected?
Radiator outlet hose usually goes to the water pump cover nipple #35.https://www.cyclepartsnation.com/oem...ne-lubrication
Shouldn't be that hard to replace.Slide clamps on the hose,helps to run a thin film of oil inside so the hoses slide on both the radiator and w/p nipple easier,then tighten clamps. You will usually need to leave the radiator cap off so you can bleed any trapped air pockets after you fill the radiator and crank it up. Radiator level should go down once the fan kicks on. You should then be able to top off the radiator,replace the cap and top off the recovery bottle if applicable.
Can't see where the 680 might have been updated or not,but looks like they sent you the wrong part compared to these.
https://www.ebay.ca/itm/NOS-Can-Am-2...hY69Jr&vxp=mtr https://www.ebay.com/p/CAN-AM-SKIDOO...691/1434112003 Thermostat housing and water pump cover are two different parts. I'd contact the seller.
dbj216
23
Sep 16, 2018 07:52 AM
larrypwilliams@gmail.com
Aug 16, 2016 08:56 PM
