Polaris Magnum 425
Old Feb 26, 2018 | 09:42 AM
blake1234's Avatar
Default Polaris Magnum 425
I have polaris magnum 425 with electrical problems. I can pull start with engine running good but no electric working. It doesn't matter if key is on or off, it will still pull start. Battery is good. I have unplugged all leads on terminal below handlebar and then reattached but still no luck with using the battery to start the engine. All work fine until about two weeks ago when I encountered this problem. All input is appreciated. I have thought about replacing the rectifier but not sure if this is where I need to start. Thanks
Old Feb 26, 2018 | 09:57 AM
Man this is getting more common everyday.. Try this first as a lot of people have solved this because either the pickup coil is getting weak(should ohm out at around 97 ohms on the white and white/red wires) or it's too far from the flywheel.Pull starts ok as the recoil starter can put more torque on the flywheel,but electric starter can't get enough speed to produce spark. Here's a post from a while back on the same thing. His rope broke and knocked the bracket back a little.Hopefully that may be your problem.http://forums.atvconnection.com/pola...ml#post3155476 Plus forgot to mention that a little dirt on the face of the pick up coil can do the same thing. Distance from the pick up coil to the flywheel strip should be between .016-0.40 Closer the better seems like.
Last edited by old polaris tech; Feb 26, 2018 at 10:33 AM. Reason: dirt on pick up coil..
Old Feb 26, 2018 | 05:04 PM
I may have misread this post also.. IF you're not getting power at all to the dash,lights,etc then it could be as simple as 20 amp circuit breaker may have faulted.Ignition is magneto triggered, separate from the battery and you can always pull start one. If you're not getting power to the dash,lights,etc,check that you have power on each side of the breaker that's in a sealed pouch. Located up from the battery on the main harness.You can slice the pouch ooen if it's not allowing voltage to go through and replace this breaker. Just a few bucks at any auto supply.
Mudd
Sep 4, 2023 07:54 PM
lhlcotton
Oct 21, 2003 11:12 PM
nitrotmann
Apr 30, 2003 01:49 PM
performax
Apr 3, 2001 07:47 PM
fourlix
May 17, 2000 07:00 PM
