High idle
Old Mar 11, 2018 | 05:09 PM
rui74's Avatar
Default High idle
I have a 2005 500 sportsman ho, it has been a great machine but lately it will idle high. Around 1900 i think should around 1200 i can not figure what is causing this now. Any ideas why help.
Old Mar 11, 2018 | 05:31 PM
Idle adjuster still mounted to the carb? A lot of times the wire holder will break and the adjuster will lay on the engine.Vibration can cause the adjuster to turn raising the idle.
Old Mar 19, 2018 | 06:20 PM
rui74's Avatar
Thanks OPT,
running great now .
Old Mar 20, 2018 | 09:47 AM
Originally Posted by rui74
Thanks OPT,
running great now .
Ok,but what'd you do to solve the problem? This helps others also that might have the same problem...
Old Mar 20, 2018 | 09:59 AM
rui74's Avatar
Adjusted idle screw, not sure why is was high the spring is intact.
Old Mar 21, 2018 | 05:35 AM
Powerranger262's Avatar
You truly have seen it all, haven't you?
Old Mar 21, 2018 | 07:53 AM
Anytime you might think you've seen it all something else jumps up and bites you on the butt..
Old Mar 21, 2018 | 10:08 AM
Hahaaa
Hightower
Jan 23, 2003 05:58 PM
IA450ES
Aug 27, 2000 09:51 PM
FOREMANes
Aug 20, 1999 09:35 AM
