Honda 350 rancher ES got gas but won’t start
Old Mar 14, 2018 | 04:45 PM
stephenwillis's Avatar
Default Honda 350 rancher ES got gas but won’t start
Honda 350 rancher ES got gas but won’t start. I put a new piston rings And cylinder on it then clean the carb up and clean the valves on the cylinder head and put a new spark plug in. I went to start it and it cranked up but would only Ideal . When I went to press the gas it would just die. It only would run in joke, the next day it would not start at all. Has plenty of gas coming into the carb has good spark turns over fine but will not start. When I first tried to start it it ask like it wants to and sometimes backfires. If anybody knows or has any idea what’s wrong please help me figure this out. I have rebuilt only one atv So I am still learning. Thanks for your help
Old Mar 14, 2018 | 07:52 PM
papa hogg scoot's Avatar
Loved
Community Favorite
May try new spark plug first,then check compression and let us know what its reads.
Old Mar 15, 2018 | 01:39 PM
I put a new spark plug in and still nothing and still nothing . I guess I need to go out and buy a compression gauge
Old Mar 15, 2018 | 03:31 PM
I have been doing some Research and I have found out that it could be the CDI box. Do you think this could be the problem
Old Mar 15, 2018 | 08:46 PM
Loved
Community Favorite
Have you ever heard it run before build job? If you remove air filter and spray carb cleaner into carb will it hit and run?Right its to early to decide on cdi yet,also other things to check before that is up to the table.
Old Mar 16, 2018 | 06:27 AM
I bought the thing about a year ago top end was locked up so I tried to go the cheap way and put a off brand piston on . Well it ran a little drove around the yard and something happened and it stop working . I found out it was the piston again so I bought a better piston and cylinder and used head cleaned everything up. It started and Idled with The choke on for about 10 minutes. Later I went to start it back up it would not start. But when I was idling if I took it off I don’t ever di choke on for about 10 minutes. Later I went to start it back up it would not start. But when I was idling if I took it off Idled it would die or if I pressed the gas. I have not been able to get it running sense then.
Old Mar 18, 2018 | 08:14 PM
Thanks for ya help it was the carburetor
rarlzaburns6
10
Oct 25, 2015 01:48 PM
bojo5321
1) Engine problems..
10
Jun 14, 2014 09:44 AM
ruddly455@yahoo.com
Dec 8, 2012 07:19 PM
roosthrower
Aug 11, 2003 03:13 AM
