Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
kasea 90 cc quad
Old Mar 16, 2018 | 04:25 PM
fatty2x4's Avatar
Default kasea 90 cc quad
bike runs great for short bursts , then will fall on its face , then it will retsart and idle fine and rev up but put a load on it , it and it wants to bogg out and die .
Old Mar 16, 2018 | 05:09 PM
I'd check that the tank vent line is open and also has good fuel flow to the carb.You could also open the drain screw on the carb to see if fuel is getting past the needle and seat. If all that checks out then I'd do a compression check. If it runs for awhile and dies and starts back up,could be rings may be loosing their seal against the cylinder wall. The Kasea 2 strokes used the same engines as Polaris,Eton,Aeon and a couple others. Polaris called for a minimum of 115 psi compression on both their 50 and 90 machines.
Old Mar 30, 2018 | 08:45 AM
LT80's Avatar
LT80 Expert
Fix it?
Old Mar 30, 2018 | 09:44 AM
Originally Posted by LT80
Fix it?
Another pet peeve of mine are the ones that never report back. Maybe he will..
Kasea90AZ
2) Chassis problems..
Dec 3, 2016 12:36 AM
410Customs
Aug 6, 2016 06:39 PM
arcsum68
12
Apr 18, 2010 08:10 AM
Prodigy
Dec 15, 2006 01:52 PM
