2008 polaris sportsman 800 twin efi awd issue
Old Mar 24, 2018 | 01:46 PM
Spank20's Avatar
Default 2008 polaris sportsman 800 twin efi awd issue
So I've had a few sportsman before but this 800 efi is new to me and the awd has me stumped. It works but only when the throttle is mashed and I'm moving at a good clip. It has an aftermarket clutch kit and 1 inch spacers. Every other sportsman I've had the awd would engage instantly even at a crawl. HELP!!
Old Mar 24, 2018 | 02:15 PM
Most clutch kits use stiffer springs,heavier counter weights. This takes more throttle to activate. Several people that I've installed kits for didn't like them and had me change the clutches back to stock after riding them awhile. You can get oem springs and weights(if they were changed) fairly reasonable at Partzilla and other online sites.
Attached Thumbnails 2008 polaris sportsman 800 twin efi awd issue-c999e5b0a22bee74378eebe4a58d7641fce1d6e1.png   2008 polaris sportsman 800 twin efi awd issue-cd3a742430cb91db205caf9dc567d318167f67c2.png
Old Mar 24, 2018 | 02:44 PM
Spank20's Avatar
So because of the aftermarket clutch it's causing my AWD to engage at a higher rpm?
Old Mar 24, 2018 | 03:14 PM
Yes clutch engagement is usually at a higher rpm because of the stiffer springs and clutch engagement is more harsh compared to stock.
Old Mar 24, 2018 | 05:30 PM
Spank20's Avatar
What does that have to do with my 4wd?
Old Mar 24, 2018 | 07:03 PM
Clutch kit or may not have anything to do with your awd engagement. Change fluid first if you haven't done so already and see if it helps. Most common problem or the weak point on later model awd systems was the plastic roller cage and armature plate wear. Even small hardly noticeable cracks in the roll cage could affect engagement.If you're having problems with it and have to tear into it replace the roller cage with an aluminum one. Polaris list an aluminum roller cage as an "option" on your model. Later models came standard with it. Item #10
Attached Thumbnails 2008 polaris sportsman 800 twin efi awd issue-8df02b61c4c07330412d997141ab3bdd9800efd3.png
Sw00p
Sep 24, 2015 02:50 PM
jdreck
Sep 7, 2011 08:34 AM
Randy1621
May 15, 2004 12:15 PM
