2003 Sportsman 700 Brake Performance
Old Mar 24, 2018 | 09:16 PM
srievley's Avatar
Default 2003 Sportsman 700 Brake Performance
ATV had sat for two years when I got it. Brake system had drained empty. I replaced the main master cylinder and put new seals in rear caliper. Ran a bunch of new fluid through both front calipers and installed EBC sintered pads all the way around. The old pads were not metal to metal yet so the rotors seem okay. The brakes work, including the foot brake on the rear, but I think they are a little weak. Should I be able to lock the front wheels? I've tried this on wet grass and they will not lock. Lever and pedal never lose pressure, and I can set the parking brake for days on end and it's still holding tight. Do I need to rough up the rotors? Is this normal?
Old Mar 25, 2018 | 08:21 AM
If you replaced the master cylinder,seals on the rear caliper,I'd replace the seals in the front calipers.They have the most stopping power. If they don't have the seals could be seeping a little. https://www.ebay.com/itm/Polaris-par...paSEZa&vxp=mtr
https://www.ebay.com/itm/Polaris-541...1Z5NCm&vxp=mtr You need two of the 779,two of the 780 seals. Shouldn't have to mess with these drilled and slotted rotors other than an occasional wire brush.
Old Mar 25, 2018 | 08:29 AM
srievley's Avatar
Should I be able to lock the front wheels? I’m just trying to gauge the expected performance.
Old Mar 25, 2018 | 08:53 AM
The split system gives most of the braking to the front,60/40 by most counts. If the brakes are in good shape,yes you should be able to lock the front wheels under heavy braking.
Old Mar 25, 2018 | 09:02 AM
srievley's Avatar
I’ll rebuild the front calipers and wire wheel the rotors and see what happens. Thank you!
Old Mar 25, 2018 | 02:23 PM
srievley's Avatar
Went ahead and wire wheeled the rotors today. Totally different machine now! The brakes work great. I think I’ll still replace the front caliper seals but it seems the rotor finish was the ticket. My next project is the ball joints. They are the worst I’ve ever seen.
nez02
Apr 18, 2012 01:58 PM
muddigger84
Jun 16, 2011 06:50 PM
dwabbit
May 26, 2011 08:21 AM
blastrocastro
Feb 20, 2004 07:36 PM
coachdad1
Mar 30, 2003 10:54 PM
