Coolster 150cc sport
Old Apr 2, 2018 | 05:34 AM
Druopp01's Avatar
Default Coolster 150cc sport
Hey guys maybe you can point me in the right direction. I purchased a Coolster 150cc to ride my kids around. I chabged the oil after the break in period ect. The nect day whike ripping with my son i had to make a U-turn, i go from drive to reverse no issue , at that point i could only get the side shifter to go back up to nuetral it refused to go into (drive) thr forward position almost like it was being blocked. I decided to turn the machine off at which time (with 0 effort) put it directly in forward and off we went ......any thoughts on whats going on? Why would it work fine stoping the engine and switching gears and why not while its running esspectialy if nuetral abd reverse gave me no issue
Old Apr 2, 2018 | 09:05 AM
Zrock's Avatar
Super Quad Patrol
Maby try turning the idle down. it may be a hair to high
Old Apr 2, 2018 | 09:42 AM
Druopp01's Avatar
The throttle was preset from the dealer, with no adjustments so i don’t think a that could be the case especially it nuetral and reverse have no issues when I come to a complete stop apply the back brake and change gears.
Old Apr 2, 2018 | 10:29 AM
Zrock's Avatar
Super Quad Patrol
Their is always a idle adjustment their should be a adjustment on carb as well as the cable for cable slack. Adjustment needs to be their as sometimes they need to be adjusted due to elevation, temp, etc. As far as shifting into reverse easily that section of the trans may not be effected the same as forward with tension on trans due to idle. The forward gear may be still a little tight until it gets more wear on it. On my machine it took about 1000km before the shifter was not as fussy
Old Apr 2, 2018 | 10:33 AM
Druopp01's Avatar
What you’re saying makes sense now I think this post may be accurate. I guess now it’s just locating exactly what you’re talking about and trying to figure out how to make those adjustments but I appreciate the help and the input greatly appreciated my friend
Old Apr 2, 2018 | 10:36 AM
Zrock's Avatar
Super Quad Patrol
no problem.. 90% of the time if a auto tranny fails you will not get it in gear with it off.. Hopefully you can get it sorted..
Old Apr 8, 2018 | 03:16 PM
Druopp01's Avatar
Default Your right
this is idle was the issue, that you very much. However I just jumped on To put it through its paces and realize the back brake is not working at all. Zero pressure any thoughts I did notice a ball of red grease on the desk had it self I don’t know if it blew a seal somewhere but it worked fine last time we rode it any thoughts
Old Apr 9, 2018 | 09:44 AM
Zrock's Avatar
Super Quad Patrol
try dome brake clean if the pads and disk got covered in grease they are not going to work. May have to replace the pads.
jazzyjt2000
May 17, 2020 08:34 AM
Indianajeff
1) Engine problems..
Dec 6, 2016 03:51 PM
chevydad6
Dec 18, 2014 07:27 AM
oren213
Dec 13, 2007 04:42 PM
