Fuel Line Insulation
Old Apr 2, 2018 | 09:29 PM
srievley's Avatar
Default Fuel Line Insulation
I am rebuilding a 2003 Sportsman 700. When I had the fuel tank off for some engine work, I found the aluminum fuel line insulation falling apart. I removed what was left of it and replaced all of the fuel and vacuum lines with Gates fuel line. Do I need to find new insulation to put back on the lines, or will it be fine?
Also, I'd like to replace the radiator overflow hose with new clear tubing, but not sure if it calls for a special hose to resist the heat and the antifreeze. Any suggestions?
Thanks!
Old Apr 2, 2018 | 10:00 PM
I'd get the aluminum sheathing for the fuel lines along with extra foil for the bottom of the tank if you can. Insulation on the lines was to keep the fuel cooler as the tank and lines received a heck of a lot of heat from the exhaust and fuel would get super hot at times to the point of vapor locking on some models. Clear tubing for the overflow isn't a major problem. Any auto supply should have it. Tell em what's it's for. They may have a tougher grade of clear hose that they may recommend.
Old Apr 2, 2018 | 10:09 PM
srievley's Avatar
The tank insulation was still good so I left it on there. I'll look for some fuel line insulation and put it back on there.
Thanks!
Old Apr 3, 2018 | 08:03 AM
What I meant was to install an extra layer of foil insulation on the bottom of the fuel tank along with new foil sheathing around the fuel lines. People have had good results doing that.
Old Apr 3, 2018 | 11:37 AM
srievley's Avatar
Will do. Thanks for the advice!
Old Apr 4, 2018 | 02:50 AM
polman500's Avatar
Heatshield products
https://335049.r.bat.bing.com/?ld=d3...d%7bmsclkid%7d
PinkFloydEffect
Technical and How-To Articles
Jun 2, 2012 04:29 PM
jackone
1) Engine problems..
Nov 26, 2010 07:12 AM
SlueFoot
Feb 23, 2005 01:25 PM
E
Feb 8, 2004 11:48 PM
ProEMTPFF
Jan 28, 2002 01:14 AM
