2000 Polaris xpedition 425
Old Apr 6, 2018 | 06:30 AM
NicC's Avatar
Default 2000 Polaris xpedition 425
My Polaris has water getting in the motor through the radiator i suppose and i can smell it when it is running but it won’t stay on unless i keep my hand on the gas. The day it happened, the four wheeler just cut off on me and when i got it to crank back up there was water shooting out the bottom end of the motor and the radiator was whistling loud. I was told the head could be crack but i don’t know to much about fixing four wheelers. Can any of you point me in the right direction?
Old Apr 6, 2018 | 07:29 AM
Radiator pressure test first. Pumping up to 10psi and it should hold this pressure. If the pressure drops it can usually be a blown head gasket.
Old Apr 14, 2018 | 04:48 PM
NicC's Avatar
I firgured out that my water done mixed with my oil and was told it’s the head gasket... will a Polaris 500 sportsman Head fit on a xpedition 425
Old Apr 14, 2018 | 05:51 PM
Nope.. Rods are different part numbers because the bore and stroke are different on each one. 87.9 mm bore x 70 mm stroke for the 425 / 92 mm bore x 75 mm stroke for the 500.
Old Apr 26, 2018 | 06:01 PM
NicC's Avatar
Can you show me what a head gasket looks like?
Old Apr 27, 2018 | 01:42 AM
You ca get an oem head gasket or an aftermarket top end gasket kit. Head gasket to the left,base gasket to the right if you have to remove the cylinder.
Attached Thumbnails 2000 Polaris xpedition 425-kgrhqn-p0fbg6dmwlibqgyu6vklw-60_57.jpg
donn92
Sep 2, 2017 06:23 PM
kuhner
Mar 15, 2015 10:15 PM
shank0668
Oct 8, 2012 06:02 PM
mlusk1
Feb 1, 2011 09:13 AM
danman10
Jul 3, 2004 12:25 AM
