Polaris predator 50
Old Apr 8, 2018 | 03:38 PM
Bart29's Avatar
Default Polaris predator 50
Hi Polaris predator 50 2006 the rod that goes through for engine mounts has 2 bearings I have play in them was wondering if there is any tutorial or correct or easy way of replacing them as the are on the engine casing
Old Apr 8, 2018 | 04:24 PM
#0451740 on the bearings. If you have the cases split a little heat from a propane torch around the bearing then slap the case on a block of wood. Bearing should fall out. If you can't do it that way rent an inner bearing puller from any good auto store for a refundable deposit. Have the new ones in the freezer for awhile. Heat the case area and the bearing should almost drop in. May take a couple taps to flush.See if this video helps.
Bart29
Apr 8, 2018 03:37 PM
