Please help with my 2003 Polaris predator 500
Old Apr 10, 2018 | 10:27 PM
Chasemusic6's Avatar
Default Please help with my 2003 Polaris predator 500
Start button/ on-off switch isn’t working. I can bump start it and it runs fine but Headlights aren’t working neither is the cooling fan. When I jump the solenoid the engine turns over but won’t fire. So far I have bought a new battery. Before I go any further with buying new parts that I can’t return maybe someone can help. Thank you
Old Apr 11, 2018 | 07:47 AM
Other than checking connectors and wiring leading into the left control switch to make sure they have good contact,cleaning the crevices of the switch with contact cleaner that's about all you can do with this switch. Some have been able to take them apart and cleaned any corrosion on the plates,but most end up with springs and brass plates flying out.Not uncommon for these switches to have to be replaced over time.Forgot to mention there is a 20 amp breaker in a plastic pouch that supplies power to the switches. If it's corroded or shorted out that can be the problem. Should be located close to the battery. Check for power on each side. If it doesn't have,slice the pouch open and replace it. Cheap part at most auto stores. Item #2 on the parts break down.
https://www.partzilla.com/catalog/po...-ab/electrical
Last edited by old polaris tech; Apr 11, 2018 at 08:18 AM. Reason: 20 amp circuit breaker.
Old Apr 11, 2018 | 09:17 AM
Ok I will try that first. Once I get the machine running I can flip the on off switch to off and the quad shuts off but when the switch is in the middle the red light isn’t on. I’ll try that circuit breaker and see what that does.
muddytrails
Sport Quads
Nov 26, 2012 08:22 PM
mimiburt
Oct 10, 2008 04:55 AM
philly
Mar 8, 2006 05:44 PM
