2007 sportsman 500 X2 efi crank position sensor
Old Apr 15, 2018 | 06:47 PM
tundravrod's Avatar
Default 2007 sportsman 500 X2 efi crank position sensor
Hello, looking for a little help here. I have a 2007 sportsman 500 X2 efi ho. It started running rough back firing and stalling, I am getting codes 44 and 47. I tested the CPS and only have .4 ohms across it instead of 185 according to the manual. The IAC test in spec. I am looking for a CPS, but it seems like all the sites I go to want you to replace the stator and CPS as one unit which seems to be quite expensive. Does anyone know of just a replacement for the CPS? Any help/suggestions would greatly be appreciated.
Old Apr 16, 2018 | 07:10 AM
This sensor is different than the ones that you can buy separate like for the 700/800s,etc. Wired directly into the stator instead of separate as all the others. I haven't looked at Ricks or Ricky stators,but you might give them a call.https://www.manualslib.com/manual/90....html?page=349
Old Apr 16, 2018 | 04:40 PM
tundravrod's Avatar
Thanks for the info OPT. I will check there.
Ruger500efi
May 7, 2014 08:21 PM
UTU
Oct 7, 2012 10:16 AM
Sportsmanfanz
Apr 3, 2009 03:41 PM
arkieshooter
Mar 28, 2009 02:58 PM
