CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
DS650 struggles under load
Old Apr 17, 2018 | 06:03 PM
BiggPigg4x4's Avatar
Default DS650 struggles under load
Hey guys, been trying to get the wifes old ds650 back to running order. Had some issues with fuel leak in storage, chased that back to bad fuel petcock also replaced fuel line. Cleaned the carb while in there. Now the thing, starts and runs fine. In nuetral you can rev the **** outta it and idles great. Get it all warmed up and take it for a ride and at about middle to full throttle it just falls on its face and sputters, sometimes dies, sometimes the idle struggles until it dies. Fires back up just fine, pull in clutch and rev it up, just fine. Take off again, same issue. We have tested spark and changed the plugs. Running outta spare headaches to use o this thing. Any help is appreciated.
Old Apr 18, 2018 | 08:43 AM
DirtDevil101's Avatar
It's probably a good idea to test your compression, if that checks out I'd move on to the clutch...sounds like it's slipping badly, friction plates might be toast...
Old Apr 18, 2018 | 05:15 PM
Default .
Compression seems to be good. Another wierd thing is, the other night outta nowhere it ran like a champ for like 20mins. Road the **** outta it. Stopped for about 10 mins. Back to same issue. It bogs/falls on face feeling like a rev. Limiter i was wonder if this is a CDI issue?
Old Apr 19, 2018 | 08:33 AM
But you said it runs fine without load...is that still the case? It could be electrical...but before going down that hole I'd confirm the compression. And I'd still pull the clutch...better yet replace it since you "Road the **** outta it"...just my $0.02...
lonerider856
Oct 13, 2023 03:45 PM
StaplerUk
1) Engine problems..
51
Jan 6, 2023 03:39 AM
jacob_royer
22
Sep 13, 2016 02:06 AM
maximus
Jul 14, 2002 02:42 AM
yam8
Jan 3, 2002 02:01 AM
