Need kill switch help
Old Apr 19, 2018 | 07:22 PM
Paramuir's Avatar
Default Need kill switch help
So have two Chinese at 110cc with the left hand controls that has the start button and lights and the kill button on them.
the kill button will not work. The atv will start and run with no issue. The brake lock out and key work.
my question is can I add a new kill button if so how do I do this.....
I tried unpluging the ground on the coil and grounding it to the frame atv still runs....only way I can shut it down it taking off the positive from the coils or choking it out....
..so debating on just putting a switch on the positive side of the coil to use as a kill switch
Old Apr 20, 2018 | 01:59 AM
First off are they AC CDIs. If they are there should be a wire goes from it to ignition switch, usually black with white tracer. This ether needs to be earthed to kill, or earthed to run, all you need is a switch in that circuit.
DC CDIs need a positive wire from ignition switch to run, so if the CDI is disconnected from the battery (normally through ignition switch), the bike will stop.
DO NOT DISCONNECT THE CDI MAIN EARTH LEAD or you can blow the CDI.
Old Apr 20, 2018 | 03:34 AM
Paramuir's Avatar
So in this photo where the whote piece of plastic is there is a yellow and red wire on theblrft side a green in the middle (assuming ground) then on the 3 spot that wire goes and connects to the red yellow. Together as one wore head to the cdi.
So the kill positions are either left or right on the switch snd run is when the switch is in the middle.
The switch will not kill will only run.....how do i fix that
It' a 5 pin cdi so I think then it' the first one
the black and white wore on the cdi doesn' that look after the lock outs....like the brakes needs to be pulled and such to work?
so if it'' is this type then I need to temporarily ground that wire to shut the bike down?
Old Apr 21, 2018 | 02:12 AM
"the black and white wore on the cdi doesn' that look after the lock outs....like the brakes needs to be pulled and such to work? so if it'' is this type then I need to temporarily ground that wire to shut the bike down?"
There may be exceptions but on most CDIs the black/white is the kill wire, nothing to do with lockouts, which are more for the starter circuit than ignition anyway. Like I wrote earlier, some are earth to kill, some earth to run, only way to find out which, is to try it.
Old Apr 21, 2018 | 02:36 AM
Paramuir's Avatar
OK so what wire in the controller am I touching to ground or where to live to try and make a kill switch
thanks
looking at just ordering new controls too....
Old Apr 22, 2018 | 01:45 AM
That photo you put up doesn't show a black/white wire, which could indicate the CDI is DC. Take a look at the CDI. Does it have a black/white wire coming out? If it has, try grounding it. If the bike won't spark with it grounded, but does when it isn't grounded, you can wire a kill switch in there. Same applies if the kill wire works the opposite way.
If there is no black/white wire from CDI and only 4 wires on it, one of them should have live battery power from ignition, the ignition switch should cut power on this wire, if it doesn't, wire it so it does. No need for a separate kill switch if turning the ignition switch off kills the spark.
Old Apr 22, 2018 | 10:03 AM
Zrock's Avatar
Super Quad Patrol
have you tryed cleaning that switch? It looks pretty rusted up and probably unable to make contact. Also looks like its missing something to trip the contact to trip the contact.
88rxna
1) Engine problems..
Aug 28, 2016 02:50 PM
AC-Greeny
May 8, 2016 04:03 PM
kfxridr
Feb 27, 2009 10:32 AM
Troyer23J
Jan 8, 2005 01:39 PM
timscherer
Feb 21, 2004 12:53 AM
