1997 Polaris Xpress 2 stroke issues, need help!
So it starts, but it doesn’t stay running and when it does stay running it starts slowing down randomly and shuts off . I rebuilt the carb and put a new spark plug into it. Not sure why it’s not working
I always start with the basics and work my way up. Have you checked for good spark, fuel and air? Look for any cracks/leaks in the carb boot. Check the fuel line for flow and any kinked, cracked or loose hoses. Let us know...just out of curiosity is the plug wet/dry after it stalls and what color?
What I would do:
1) verify your compression...a low compression motor may start and idle but once warm and expansion occurs you may not have enough compression to keep it running
2) after #1 is verified, I'd have to ask you exactly what you did to "rebuild" the carb...as that means different things to different folks...
3) it sound like a potential fuel starvation issue...if the carb checks out pull the fuel line off the carb and verify good flow from the petcock
What I would do:
if it will run on choke but will die when you shut it off, then it's lacking fuel.
itch
25
Oct 10, 2011 02:14 PM
rudd21
Jun 3, 2009 07:34 AM
