Baja Wilderness 250 - oil leak / won't start
Old May 14, 2018 | 07:25 PM
GarAtv's Avatar
Default Baja Wilderness 250 - oil leak / won't start
I was riding my Wilderness 250 - stopped to do something - got back on - and could not get into neutral.
I noticed oil leaking out in a steady flow on the left side of the atv - by the clutch. I had quite a puddle of oil on the dirt.
I had to push it back home.
Upon further investigation - I believe the issue is the "neutral Switch is broken" (which is a wire that attaches to a spot where oil comes out). Would anyone agree/disagree? Is the fix straight forward?
-Gar
Old May 15, 2018 | 09:11 AM
Zrock's Avatar
Super Quad Patrol
Would need pics
Old May 15, 2018 | 01:01 PM
GarAtv's Avatar
Hi
tha k you for the reply
two photos attached. this is area in question.
the oil is comong out of the hole and the electrical cable appears to have once been attached.
the hose is the overflow, I believe.
the oil is coming oit of the hole
Old May 15, 2018 | 03:39 PM
GarAtv's Avatar
1 is where the oil is leaking from
2 is what I beleive is the neutral switch
Old May 16, 2018 | 02:41 AM
Looks a lot like a broken plunger switch. I would have expected the gears to still work though, so maybe the plunger part has shot out and jammed something. Only way is to get a new switch, and see what the old one looks like when you unscrew it.
Old May 16, 2018 | 09:02 AM
Zrock's Avatar
Super Quad Patrol
Ya i would say your on the right track.. Take a light and shine it in the hole after you remove make sure no pcs are in their as well as pull that big plug out beside it and see what you can see.
Old May 16, 2018 | 09:30 AM
GarAtv's Avatar
Thank you for the replies. I'll take the advice and report back what I find.
BTW, does anyone have a photo of what this area on the bike should look like? It may help me compare...or what I should be looking for.
Really appreciate the help!!
gar
Old Jul 8, 2021 | 07:57 PM
Problem800's Avatar
Hi, Same happend to me. How did you solve it?
gar
wingingit2
Technical and How-To Articles
Dec 12, 2015 07:41 PM
CWESTE
Nov 1, 2011 12:00 AM
Justaboutgeese
Oct 11, 2010 06:47 PM
PhireDawg
1) Engine problems..
Jun 3, 2010 06:24 AM
