Fuel tank connecti0ns on 650 V2 2005
Old May 15, 2018 | 09:54 AM
DustyJohn's Avatar
Default Fuel tank connecti0ns on 650 V2 2005
My fuel tank vent hose dried and cracked below the seat. It seems to terminate above the handle bars up behind the Gauges. Do i need to disasssemble the guage cover to reconnect the new tube or is it vented to athmosphere?
Also noticed a hose coming off a "T" from hi up the left side of the Carbs at the choke vacuum cover, (Believe it is Item 54 on the exploded carb diagram) that again goes up under the Gauges, Does it connect or is it open to atmosphere?
Old May 15, 2018 | 07:30 PM
hydrex's Avatar
I believe both vent to atmosphere. I've seen some guys put a tiny fuel filter on , maybe to keep creepy crawlers out? You should check the boot between the carburetor and air box for cracks. I've seen it on 01 and 02 Cats. My mechanic said he had an engine failure on an older Cat, when it sucked water thru a cracked boot.
Ryan Mann
Apr 18, 2018 08:34 AM
Ryan Mann
Apr 16, 2018 02:23 PM
Pontiac69!
Apr 14, 2018 08:36 AM
Twitch08
Feb 27, 2018 06:48 AM
Stephen Sallows
Ask the Editor
Nov 26, 2016 09:44 AM
