I have a suzuki LT80 that wont start.
Old May 20, 2018 | 01:10 PM
defman555's Avatar
Default I have a suzuki LT80 that wont start.
I have a suzuki LT80 that wont start. There is a clicking noise, but it doesn't come from the starter, it comes from the relay switch.
It's kind of a pain because the quad is at our property in the middle of nowhere with no phone or wifi , so if I just buy a knew relay and that isn't it, I have to wait for something else.
I've already bought a knew battery
Old May 21, 2018 | 03:24 AM
Have you pressed the re-set button under the rear wheelarch. Early LT80s didn't have it, but it is there to blow, like a house trip, if the starter gets overloaded. Why did it trip? Can be just one of those things, or the engine locked due to you leaving it on PRIME and fuel filling the sump & cylinder. If it isn't the overload button, I go for the test lamp method. 12v lamp connected between good earth on engine and starter live post. Press start button, solenoid clicks and lamp doesn't light, faulty solenoid or overload button, or bad earth, if lamp does light, faulty starter. You can narrow it to either solenoid or overload unit by testing with test lamp lead on wire between them.
jashworth
Mar 17, 2020 03:09 AM
410Customs
Jul 27, 2019 10:14 AM
ELMOELEMENT
Dec 6, 2007 06:05 PM
AlaskanATVR
May 19, 2005 02:50 PM
