Lt80 won’t start
Old Jun 9, 2018 | 09:05 AM
Vciferni's Avatar
Default Lt80 won’t start
I have a lt80 that was sitting for a little. Ran when I put it away. I put a new carb on it and went to pull start it and it won’t turn over. I checked and I do have spark. Can’t get it running on starting fluid either. Not sure if there is something electrical keeping it from turning over. Thanks in advance for the help
Old Jun 9, 2018 | 02:56 PM
LT80's Avatar
LT80 Expert
So the motor spins, just no start. Right?
If you meant that you were going to pull the machine with another and start it, it won't start. You can't pull start a CVT.
Is the plug wet after trying to start?
Is there air coming out of the exhaust when motor spins?
Did you try a new plug? Sometimes plugs won't fire under compression.
Old Jun 9, 2018 | 05:18 PM
Vciferni's Avatar
Yeah it spins, and it does have a pull starter on it. Not sure about the other questions but I’ll try new plugs.
Old Jun 9, 2018 | 06:54 PM
LT80's Avatar
LT80 Expert
OK, I was wondering (pull start).
rumblefish1973
Dec 28, 2025 04:34 AM
ZukiSu
Mar 20, 2005 11:29 AM
bluenoser
Sep 21, 2004 10:32 AM
yfz450bb07
May 17, 2004 03:44 PM
confusedbuyer
Apr 12, 2004 02:37 AM
