2015 ETX Speedometer/Gauge Problems
Old Jun 9, 2018 | 08:43 PM
Seacattz's Avatar
Default 2015 ETX Speedometer/Gauge Problems
I just purchased a 2015 Polaris ETX and the speedometer and gauge cluster does not work. When the key is off there is a slight blue backlight coming from the right side of the cluster. When the key is ‘on’, there is nothing. The analog sppeedometer doesn’t move. The LCD display is blank. None of the warning lights ever illuminate. AWD seems to be working. Any ideas?
Old Jun 10, 2018 | 08:31 PM
Seacattz's Avatar
Default Update
After sitting in the hot Florida sun for an hour this morning, the Speedo and LCD worked perfectly for a few hours until I hit a large puddle. While the screen was working, some condensation could be seen on the inside of the lense. I obviously have a moisture problem but have no idea how to correct the problem.
Old Jun 10, 2018 | 09:23 PM
user493's Avatar
Moto Psycho
I can't tell you where the moisture is getting in, but a lot of people have replaced their expensive speedometers when they didn't work for one reason or another. Check out post #20 by TaterTots on this thread to see what's involved in taking one apart if yours comes apart the same way. They aren't made to come apart so you can fix it, but you can try. You may be able to dry it out and seal it up.
https://atvconnection.com/forums/pol...-t-work-2.html
Old Jun 24, 2018 | 11:35 AM
Seacattz's Avatar
Thanks jumbofrank. I am not convinced the gauge is the problem. Some days it works perfect. Other days it won’t work at all. Gremlins?
Old Jun 24, 2018 | 03:21 PM
user493's Avatar
Moto Psycho
With electrical problems anything is possible but you shouldn't be getting any moisture inside the speedometer. It could be causing shorts or corrosion.
Steven51
Mar 11, 2017 08:54 AM
buckeyparker
Feb 23, 2017 01:46 PM
buckeyparker
Feb 23, 2017 06:16 AM
ZuluWhiskeyFox
Nov 11, 2015 07:08 AM
WilliamBos
Dec 15, 2014 12:41 PM
