Ds650 baja starting problems
Old Jun 25, 2018 | 05:07 AM
Stump1013's Avatar
Default Ds650 baja starting problems
Ok guys needs some help asap ready to set this thing on fire..thing would never start valves were tight i adjusted the calves to correct shims on intake n exhaust have plenty of clearance in between cam lobes n shims..problem is i done set tdc about 10 times now its dead on..will not fire one hiccup sprayed gas into carb while cranking n while not all it does is make a loud backfire n some flames come out. Its like valves are tight but there not.idk how it could be firing wrong with it at tdc. I need help asap carn is clean have plenty of spark bright blue.
Old Jun 25, 2018 | 07:33 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Check out the CanAm section here. Probably get you some more help and answers.
Old Jun 25, 2018 | 07:35 AM
Stump1013's Avatar
Ok. Thanks
Old Jun 25, 2018 | 12:39 PM
Welcome.
Old Jun 25, 2018 | 07:43 PM
Stump1013's Avatar
Default .
You have any ideas on what it might be.. Can the pick up coil be advanced and thats why its throwing timing off?
Stump1013
CAN-AM (BRP) Ask an Expert!
16
Jun 24, 2018 09:08 PM
bird720
Feb 16, 2013 10:23 AM
MotoXtreme
Jan 18, 2004 07:00 PM
bajads
May 12, 2003 12:15 AM
