49cc a t v wont start without using either
Old Jun 28, 2018 | 01:47 PM
flussterd's Avatar
Default 49cc a t v wont start without using either
my grand kids were given this 49cc atv because it wont start I have had the carb off cleaned it and again wont start with out either turns over like maybe the valves need adjusted is this a possibility
Old Jun 29, 2018 | 01:50 AM
Yes, if the engine has low compression, either due to bore scoring, wear, burnt valve, or clearances closed up it would be bad to start. Re-set the clearances at TDC on the compression stroke, and see if that does the trick.
Old Jun 29, 2018 | 12:08 PM
flussterd's Avatar
Default valve adjustment
could you tell me what the gap is for the valve adjustment is
Old Jun 30, 2018 | 01:45 AM
No idea, but if you try 0.003" for both, compression should come back if valve clearance was the problem.
Old Aug 28, 2023 | 01:12 PM
Hetwex's Avatar
If you need to adjust your valves on a GY6 moped I recommend 0.004 for the top one (intake valve) and 0.005 for the bottom one (exhaust valve). But make sure to make the adjustments when your piston is in its top death center. This can be done by inspecting your flywheel and aligning the T letter to the lining mark and if so also check the camshaft lining. It should have two small holes that should be perpendicular to the cylinder head and also a bit hole on the camshaft that is facing outwards from the cylinder head. This way your cylinder should be in its top death center. Then you can adjust your valves. That is what I know. Hope it helps.
Dsaulen
1) Engine problems..
Aug 28, 2023 01:20 PM
VENOM_MOTORSPORTS1
Oct 13, 2016 05:10 PM
rstrebler12
Apr 19, 2011 11:45 PM
MiZZiE
Mar 14, 2010 12:00 AM
dirtyduece_30
May 27, 2009 05:19 AM
