New top end now won’t idle
Old Jun 28, 2018 | 07:18 PM
Luttqui1's Avatar
Default New top end now won’t idle
Just put a new top end in my 2002 polaris Scrambler 400 2-stroke. The water pump seal went bad and lost all my coolant and overheated the engine and melted a piston. Got it all back together and it started up and runs great but I can’t get it to idle at all! If I let go of the gas it just dies. If I give it any choke it dies. If I hold the throttle just a touch it will idle perfectly. I’ve messed with the carb idle screw but it isn’t effecting anything. Any help is appreciated!
Old Jun 29, 2018 | 09:06 AM
DirtDevil101's Avatar
How long was it sitting while doing the rebuild and did you drain your carb? I'd give it a good cleaning (specifically targeting the idle (pilot) jet that sits deep inside under the bowl) and see if that does the trick. Just be careful getting it out as they are known to strip if you don't use a very good fitting (and small) screwdriver...
My $0.02
Old Jun 29, 2018 | 04:20 PM
Luttqui1's Avatar
My $0.02
I will give that a try thanks.
Old Jun 29, 2018 | 04:51 PM
Luttqui1's Avatar
Where is the idle (pilot) jet located?
Old Jul 3, 2018 | 08:02 AM
Inside the bowl, next to the main jet, but inside the casting. The main jet is a brass screw with a hole in it (can't miss that). You will need a very good fitting small screwdriver to get it out...good luck...
bugsquawsher
Jan 31, 2009 08:35 AM
1882
Dec 31, 2008 09:31 PM
bigblack316
May 24, 2008 05:48 PM
robyz450f
Jul 7, 2003 04:00 PM
