1994 Polaris 400 sportsman 2 stroke
Old Jun 28, 2018 | 09:02 PM
Ry Ran's Avatar
Unhappy 1994 Polaris 400 sportsman 2 stroke
Hey all, I the two wires ( red white and red) from the key switch touched and then i lost spark. i smelled a little plastic burn but i cant trace it back to anything. I have replaced the CDI, Spark plug, stator and rewired the whole board. still no luck! bunch of crap. Looking for some help please!!!
Thank you!
Old Jun 29, 2018 | 06:54 AM
hydrex's Avatar
Have you checked all your fuses? Next, try a new ignition. BTW, I had a 96, it was a hoot once I fixed everything wrong. Also, if your exhaust runs hot, gut out the muffler. Mine was plugged with 5 pounds of soot.
Old Jun 29, 2018 | 04:25 PM
Ry Ran's Avatar
Default No luck
I have tested the ignition system all and no luck still!
thanks for the tip bout the mufler. ill have a look at it once i get er running again.
Old Jul 9, 2018 | 09:54 PM
cornermike's Avatar
Check the little circuit breaker in the little black pouch back by the battery. You may have fried the ignition switch also.
Mike
Old Jul 9, 2018 | 09:58 PM
Ry Ran's Avatar
what am i looking for on that circuit breaker? the thing is that i . get a tiny little light when i put a spark tester on and crank with elec and it doesnt do squat. itll fire up with pull though.
SDR-II
Sep 29, 2015 01:06 AM
MMCK8039
Aug 21, 2008 02:15 AM
cmatthews24
Utility ATVs
Mar 3, 2005 02:21 PM
ZoomZoom
Oct 15, 2001 06:40 PM
