starter replacement
Old Jul 22, 2018 | 08:05 PM
BcTonyC's Avatar
Default starter replacement
How do I replace the starter on a Snul 125cc quad?
Old Jul 31, 2018 | 04:53 PM
Jered651's Avatar
Not sure on that achine but usually pull the hot wire fro the stud and remove 2 bolts and pull it out. Most have a O ring on them so they pull out hard
Old Aug 1, 2018 | 01:58 AM
I think it is a stretched Honda Cub clone motor, if so it will have a sprocket on the end. To fit a new starter on these, you need to remove the cover over the flywheel, once the starter is un-bolted the chain can be hooked off the old one, new one put through the mounting hole, chain hooked onto it's sprocket, and bolts re-fitted etc.
bubba143826
1) Engine problems..
Aug 19, 2016 07:32 PM
cornermike
Aug 13, 2016 09:33 PM
1stimer87
Aug 9, 2016 02:29 PM
atom0s
Jul 22, 2016 01:54 AM
06cumminsman
Jul 21, 2016 02:17 AM
