97 xplorer 300 drive belt
Old Jul 23, 2018 | 02:41 PM
SuperBill's Avatar
Default 97 xplorer 300 drive belt
I just recently bought a 97 xplorer 300. They said it got a new drive belt but at idle you can hear the belt randomly slapping on the cover. Does anyone now what this means? Wrong belt? Clutch out of adjustment? I don't know if it did this before the new belt but when I did the belt on my other Polaris it was nice and quiet. Thanks!
Old Jul 23, 2018 | 03:27 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would guess wrong belt, but take off the cover to investigate and then check the belt numbers to be sure. good time to clean out the clutches and do a once over to make sure everything is good as well
Old Jul 23, 2018 | 04:04 PM
jstjoehere's Avatar
They might not have sanded all of the rubber off of the clutches and its catching. Wierd that it does this idling usually its a problem when coasting when the clutches are disengaged. Definitely check that belt and look at the clutch facings you dont want to see any black on them take a little 220 sand paper and shine them up if they are blackened. I always take mine off pull them apart and scotch brite them
Old Jul 23, 2018 | 05:06 PM
SuperBill's Avatar
Thanks guys. I will pull the cover and check it all. The guy I bought it from thought it was a 94 when in fact it's a 97 so he may gotten the wrong belt. I will run some numbers and clean up the clutch faces a but and let y'all know.
Old Jul 24, 2018 | 03:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
don't forget to blow out all the belt dust as well!
blazeC2
Apr 25, 2012 10:12 PM
jay929rr
Nov 8, 2011 07:49 AM
tguil
Oct 22, 2004 08:38 AM
IceWolf
Dec 28, 2001 10:39 PM
