Bayou 220/250 flywheel help
Old Jul 26, 2018 | 10:05 PM
Douglaslarose22's Avatar
Default Bayou 220/250 flywheel help
Hi, the engine in my 03 bayou 250 locked up due to a bad oil pump and all the inner workings are shot. I was able to score a "running" 220 engine of an 92 bayou for only 90$. The problem now is that the charging systems are diferant. The 250 stator will bolt right on but the 250 flywheel sits to high to make a field with the pick up on the 220 engine. I can't raise the polypeptide or I will hit the stator cover when reasembling. could I use a later model 220 flywheel 99,200 etc ..to fix this or is the later model 220 flywheel the same as the 250. Let me know, any help is greatly appreciated.
Thanks . Doug
trbst11
Aug 14, 2018 11:13 PM
damien4063
Mar 7, 2011 08:58 PM
Rifleman
Feb 23, 2001 10:39 PM
big4x4
Mar 2, 2000 09:46 PM
