LT80 pull start
Old Aug 7, 2018 | 10:38 AM
koliver811's Avatar
Default LT80 pull start
Currently my LT80 does not have a pull start only electric start. The starter has started to not engage every time so I feel A new starter is coming soon. Has anyone ever installed the pull start as a back up ? On a side note when I buy a new starter is everyone buying the $20.00 starter of Ebay or is there a better option. I dont mind spending the money if it is worth it.
Thanks
Old Aug 8, 2018 | 11:22 AM
DirtDevil101's Avatar
Yes...I have the pull start...and it works rather well...ebay starter is fine...
Old Aug 8, 2018 | 02:11 PM
koliver811's Avatar
is it just a matter of removing the cover and bolting on the recoil pull start? Seems like it would make sense to have for a back up if it is simple and cost effective to add it.
Old Aug 8, 2018 | 04:03 PM
Simply, yes...cost effective...that's debatable...
I think every electric start wheeler should have another way to get it going (my Scrambler does)...let's face it...a car having a battery failure on the side of the road is not the same as an atv dying in the middle of nowhere...
Old Aug 8, 2018 | 06:34 PM
koliver811's Avatar
Just to clarify if I buy the whole assembly for 90ish dollars I simply remove the cover and bolt on the pull starter....I could not find a blown up diagram. As always thanks
Old Aug 9, 2018 | 10:52 AM
You are correct...very simple install...
Old Aug 10, 2018 | 07:57 AM
LT80's Avatar
LT80 Expert
You must use the gasket from the cover to the pull start. It acts like a spacer.
Partychief67
Apr 23, 2024 03:55 AM
hawaiianbasshead
Mar 26, 2010 05:55 PM
prairie650and700
Apr 18, 2004 10:20 PM
confusedbuyer
Mar 1, 2004 08:19 PM
bsb64
Jun 7, 2003 11:27 PM
