Re-Packing muffler
Old Aug 25, 2018 | 03:06 PM
Atvrder's Avatar
Default Re-Packing muffler
Has anyone taken apart their Bayou 220 muffler and re-packed it ? I feel like since mine is almost 30 years old.. i want to re-pack it. I use it hunting and any silencing I can get would be great. I just want to know if its worth it or not, and if you can leave the muffler on to re-pack it or do you have to take the entire thing off first ? I have no idea how to open it up.
Old Aug 26, 2018 | 02:14 AM
I would be very surprised if you can "re-pack" it. Most silencers are packed, then welded together at the factory. Fairly sure Kawasakis have "baffle boxes" anyway, without any packing in them.
Old Aug 26, 2018 | 12:29 PM
Kymco 450i's Avatar
The factory muffler is not designed to be repacked, but that doesnt mean it cant be done. If you have the tools and knowledge it can v done easily. Remove the muffler and cut off one end cap. These are welded at factory, the reason they were not intended for rebuild. Muffler case must ve solid to start with. Pull out old packing which is probably gone by now anyway, then add new packing and reweld cap.
Old Aug 30, 2018 | 02:25 PM
grapehead's Avatar
Put up some pics and results if you tackle it, I have a spare laying around that I would probably tinker with if you get good results.
Old Sep 3, 2018 | 03:52 PM
Atvrder's Avatar
Ok after looking around a little more I’ve decided not to try taking it apart. It looks welded solid and I don’t weld.
Has anyone replced the muffler on a 220? I want to get more quiet than stock so is there any direct fitting replacement?
SAMCOEDS
Feb 11, 2003 12:23 AM
wshrdskin
Mar 31, 2002 09:45 PM
hink250r
ATC 3-Wheelers
Jun 28, 2001 02:39 PM
ScoobyDFW
Jun 1, 2000 10:59 PM
rhino99
Apr 8, 2000 05:11 PM
