Need Urgent Help! 2008 Polaris Phoenix 200 bearings
Old Aug 30, 2018 | 09:53 PM
Preddy90's Avatar
Default Need Urgent Help! 2008 Polaris Phoenix 200 bearings
So I picked up a nice money maker yesterday with an apparent tranny problem, it was just rebuilt by a shop but was making a nasty grinding in forward and reverse. I tore out the engine and dissected the tranny. Gears and everything in there looks new. I thought the drive clutch felt wobbly but that bearing looks fine. The idler gear had substantial wobble on the side of the clutch. After removing it was clearly a destroyed bearing. Here is the trivia question for you all....what the heck is that bearing part number? Please help
Old Aug 30, 2018 | 10:14 PM
user493's Avatar
Moto Psycho
You can check for it here. http://parts.polarisind.com/browse/Browse.asp
Old Aug 30, 2018 | 10:27 PM
Preddy90's Avatar
I can’t get that to work but every oem diagram of tranny doesn’t show any bearings . I believe they are found in the case drawings, however it’s not clear to me which bearing it is on the case drawing. I have a choice of like 3.
Old Aug 30, 2018 | 10:31 PM
Preddy90's Avatar
I know I could mic it and get generic bearing with the same dimensions. But figured part number would be way easier, maybe not
Old Aug 30, 2018 | 10:37 PM
Preddy90's Avatar
It’s the bearing that this idler gear uses. This is the side with the big gear, the other side uses a different sized bearing (which I don’t need)
Old Aug 30, 2018 | 10:44 PM
user493's Avatar
Moto Psycho
That link works for me. They show a 2008 ATV PHOENIX 200 - A08PB20AB/AD and a 2008 ATV PHOENIX 200 - A08PB20EB. I don't know if they all use the same parts or not. I'm not sure what to tell you besides try it again. Good luck.
Gor187
Sep 18, 2017 02:16 PM
miassmaro98
May 7, 2009 12:40 PM
Ruca
Feb 23, 2005 12:03 PM
onetouch8100scanner
KTM
Feb 1, 2003 11:12 PM
