Prairie 360 squeal in front end
Old Sep 4, 2018 | 05:29 PM
Tdj2591's Avatar
Default Prairie 360 squeal in front end
2007 model. Has a squeal that seems to be coming from left front. Sorta like a bearing squeal. Sound changes when suspension flexes going over a bump. If a bearing, where are they located and how easy to change? Anything else that could cause it? It squeals in 2wd. I've only ridden it twice and don't know if t also squeals in 4wd.
i just bought this ATV. It is in excellent shape and looks like it has never been in the mud.
Old Sep 5, 2018 | 01:59 AM
Bearings are where you would expect, in the hub, just behind the brake disc. Jack the machine up on the frame under the front diff, and see if there is play in the bearings by rocking the top and bottom of the wheel. There can also be play in ball joint and track rod ends so check visually where the play is. Haven't done it on a Prairie, but KLF wheel bearings are fairly easy to replace, and I expect the Prairie to be no more difficult. If the wheel bearing is OK check the brake caliper, if a bike has stood for a while the piston or caliper sliders can seize.
Old Sep 5, 2018 | 07:08 AM
Tdj2591's Avatar
Thanks merryman. I looked at a parts diagram and didn't see the wheel bearings. I'll check it out like you suggested.
bodatiouskid
Sep 3, 2014 07:23 AM
OuterLimit
Apr 9, 2004 11:57 PM
wildwill
Oct 2, 2003 12:15 AM
Woodsmith
Oct 14, 2002 10:57 PM
